Just wanted to let you know we do have these in stock in black and in white.
http://www.gobigparts.com/NXT-LVL-HANDLEBAR-FLY-RACING.html
ATTENTION RIDERS: “Get lower to your sled, take control, and let my new NXT LVL bar from Fly Racing take your riding to the NEXT LEVEL!”—Dan Adams Next Level Riding Clinic
The new NXT LVL bar from Fly Racing will help take your riding to the next level.
Designed and tested with one of the industry’s most technical backcountry athlete’s, Dan Adams from Next Level Riding Clinics
NXT LVL specific bend will improve handling and increase control of machine
Will lower the center of gravity which causes the machine to feel less “tippy” a trait found on new body style machines
Made from 2014 aluminum allowing for greater flex through bumps to help reduce arm pump
Bead blasted finish for added strength
Standard 7/8” diameter
5 3/4" height with an 8 degree pullback
Will accept Fly Aero Taper, SLP Pro Taper, and Polaris Pro Taper style handlebar hooks
Grip area is wide enough to accept oem controls and handguards
Adjustment lines on the end of the handlebars allows you to cut the bars down to your preferred width
Crossbar is drilled to accept mountain strap--Mountain strap not included
NXT LVL handlebar includes Fly Racing crossbar pad
Crossbar pad made from heavy duty woven material, wont crack in cold temper
![18-95280W.jpg](http://www.gobigparts.com/images/D/18-95280W.jpg)
![18-95280.jpg](http://www.gobigparts.com/images/D/18-95280.jpg)
