fluidin out
E
e pimpin
New member
new stator got good spark, good compression about 125 but i can get it to run. replaced the stator and got it runnin, rode it around the block and just all the sudden died and cant get to fire again.the pipe is full of gas, i took the carb off to check the floats and they seem to work just fine. fuel pump????:face-icon-small-dis
Check your needles to make sure they are both tightened down. I bought a used 800 with a bad flooding problem and one of the needles was loose. It would ride up on the slide opening the gas flow from the main jet.
