flooding 03 600 1m
Z
ZRIDE
New member
cant keep mag side cyl from filling with fuel? replaced pistons& rings.eecu numbers match 02 1m? throttle needs to be open to start? any info ????? thanks zride
choke seat not closed
had the same problem once ,the choke cable was not adjusted down far enough to close the seat so it would always flood out. try adjusting it deeper into the seat ,my o-2. hope this helps.
the 03 600 1m is efi only, no choke. Got to be a fuel problem, leaky injector? Swap injectors see where your problem goes. I am assuming it is filling up while not in use?
flooding 600
correct efi . flooding occures when running on low end.broke down and took it to the dealer to hook up to computer .300$ later they think ecu is bad.so looking for good used one .any suggestions? thanks for the info zride
