Flex edge track on a TNytro????
Matte Murder
Do you thing a flex edge track off a Ski Doo would hold up to a 270HP MCXpress turbo set up? Very impressed with this track. 16" wide, 2.5" lugs. Would think it would make the Nytro that much better in the trees. But I don't want to shred one and just wonder how tough they are. Have Commander Extreme now. Also, what would you use for drivers? Anything I am missing? Thanks for the help.
I put this track on my 310hp turbo apex at the start of the season. Track is phenomenal! Makes the big ol girl more manageable in the trees and the hook up is insane! I am in the process of taking it off right now but only because I'm 270lbs and that much horsepower with that track and an ez ryde suspension and my weight don't work! Wheelies are a serious problem! I'm putting a 174" and timbersled suspension in and hope that helps. My buddy bought the track and is putting it on his 310 turbo apex as well but he's only 135lbs and has an M10 suspension so I'm sure he'll be fine. I used 7 tooth avid 2.86 drivers and it all fit together like a dream. I put about 400km on it before taking it off and it still looks like brand new. Give it a try, I'm sure you'll be happy.
Thanks. I have a Kmod so wheelie control should fine. So the drivers are the only change? I know you said 2.86 avid drivers but where they extroverts?
I would have thought that the 16" wide track would be an issue rubbing in the tunnel. Any modifications to get it to fit?
just have to grind down the bolts on the front skid mounting plate takes just a few minutes.if you have it perfectly lined up it dont rub but has to be perfect.
