D
Dirtdiver
New member
Switching from flatslides to rounds & I run into two problems. My dpm rail only has two small hoses for the flats & the rounds need 4. Can I tee off the left of the carbs to the dpm, then the right. Because the flats are hooked together there is only one supply hose from the fuel pump, the rounds each need one. Can that be teed also. Is on a 01 summit. Thanks Colby
