Flat tire on the hawk?
Anybody had their hawk hit the deck when they went over a bump and not pop back up??
04 600 Hawk with extreme suspension.
When we pull it back part it comes back up but after a few more bumps it hits the floor again and is flat.
Water in the shocks??
What do you think and what do we need to do to fix it?
Thanks in advance!
  • Like
Reactions: cwh
You hafta pull a couple of rebound shims out . They had to many in on the 04s so when it goes all the way down it will sometimes stick . Had that problem with 3 of em a few years ago revalved to less rebound shims no more stick downs !:D
your track could be to tight too! also put 1" shock bumpers on your shocks when you do your next rebuild! this will help stop the point of no return on your skid! thats just what i heard fron some outher guys in the know! want your skid to rock go with a 80-180 progressive front shock, and 250-500 progressive in the back!
Hey Drills .o4's had this problem when the springs are loosened. Keep adding pressure to the rebound until it is gone .That will be the softest position avail. unless you revalve and respring .
