Anything you can do to keep case temps up will help the issue the most. While a fuel controller is great and all, the root cause of the problem is not getting enough heat in the case. That fine powdery ice crystal snow we ride in saps heat from the aluminum case so fast it's insane. Any kind of skid plate, closed cell foam between the case and the plate, case shielding.... anything helps. Keep the temps up, the rings will seal better, and you'll get far less blow-by.
yes what Rush said.
I have a farly large front snow deflector that wraps to the left side of the bike and fairly big plastic skid plate and rear snow splash guard (from the track throwing snow forwards) and block the rads as needed and I have no problems keeping temps up even in powder, now I just have to figure the best temp to keep the bike at.
NO FAIR! I went on my first ride this Sunday and I didn't have all those nice easy slopes and open glades to practice in. Unfortunately the snow conditions are so bad that we have to go up in the mountains, so it was trial by fire for me. Still had a blast, although I dropped it a few more times than that. Luckily I went with some great riders that babysat me all day. Still working on the video.
How much does a rad block(plastic in front of radiator right?) help?
Rush-thanks for the info, my airbox was 3/4 full as well. Do you have any pics? Also the air temp was about 6 degrees F
Teal-what does the one for a Crf450 cost? And do you have one in stock?
