firecat d&d 900ss
What sled do you have this installed on, single or twin pipe, what intake are you using. I have the same motor in my 06 m7 and I run at 1300ft
what clutch set up u run. i just put that same motor in my 06 m7 153 with a single D&D pipe. im at about the same altittude
i am running MDS weights set at i believe 83g and a gold cat spring all stock secondary. I also have the single pipe on mine call steve at MDS he had so much knowledge with this motor it was unreal. i am running mine with a +4 timing key and 98 octane fuel it is a blast at low elevation stands on the tail until whenever you let off
right now i have no set up but i will put in +4 key in i have twin pipe i will bass is ported jug are trail ported try a few combination until i get something good.
i do now but i only had very little time on the set up. plus still breaking in the motor. and didnt put the timming key in yet
