Firecat Bored out EFI Throttle Bodies. 48mm (stock is 46mm). Uses Custom D&D fins.
I have the throttle bodies (minus injectors) off a 2003 F7. They have been bored out to approx. 48mm. D&D sells the fins that are installed in the modified throttle bodies. I believe these will work on all Firecat model years - you'll need to confirm before buying. Best use would be a ported F7 or BB F7.
No modification needed to intake boots since these are stock EFI throttle bodies, just hook up your oil arm to the throttle bodies and your injectors and your done.
$275 shipped to the lower 48. This is a lot cheaper route than buying the new larger throttle bodies some of the performance shops sell.
