Fine silver powder under hood on M7
garciava
I pull the M7 out of the trailer to do the pre season maintenance and there is a very fine silver powder dusting all over. Anyone have any ideas what it could be coming from? I am thinking the silver exhaust cover but not sure
Fiberglass from around the pipe clam shell maybe. Vibration will grind it into shinny powder.
Jason
thanks for the thoughts
I silicone the crack with high temp silicone between the two halves of the pipe insulation cover to see if that helps
I also pulled the clutch and will tear it down and check the rollers. I hope it’s not the clutch because it was a new clutch last season
If you left it in the trailer all summer, it's oxidization on the aluminum, you can stop worrying!
