Finally got a new sled....
After what seemed like an eternity on my 2002 Summit 800 Sport 144, I have moved up the ranks and purchased a 2008 Everest 154, it came with an RKT head and an aftermarket can (not sure which brand???). So my question is, which mods/tweaks should I do? :D
Nice, You'll love it.
Out of experience the first thing I would do is get the clutching perfect, Really Helps.
Then I would ditch the sway bar, soften up the suspension (depending on your weight).
That will realy help the handling.
<<<<<<<<<DEFINATLEY a Skid-Plate.>>>>>>>>
You already have the only motor-mods you'll need.
Maybe Flo-Rites in the Air-Box.
Remove all Unnesessary foam etc....
Congrats on your new sled and have fun
1- DJ helix or the 44/33 doo will work good enough
2- USI thriple threat skis worked the best for me
3- BOSS seat (good luck getting one)
4- Order a new bumper now, will will need it
5- skid plate
6- Smitty has a sweet drop down kit, i think its $95ish
7- buy a clutch puller and forks if you dont already have them, clean the hell out of the primary if its dirty, repet this process every 3-4 rides until the original factory added funk is gone, the guy before you have have done this already??
8- pull the sway arm linkage, zip tie the remaining arm to the sled somehow
9- trim each side of your track, basically remove about 1/8" off of each side, it will rub and maybe cause real damage
10- check the drive shaft, a few of them broke the whatever ya call it weld on either side, most broke on the chaincase sidee
11- does it have the original gearing?....is so, Doo will gear you do for free, see a dealer
12- the the hand warmers work, this is also under warrenty
Have fun, the XP is still the best sled i have ever had/ridden....
Well, apart from the obvious:
Changing out the jackshaft to accept a real secondary,
Heated grips, drive shaft repair, etc.. I would just ride it.
I myself would not drop the back end. My Rev has it done to accept the 2.5" track, and it is a dog to handle in set up snow... can't see it being any different on the XP. In the deep it does rock, but I am talking about
4 feet plus. I am thinking of removing the drop, and going with a smaller upper idler. I compared the 2 setups, and I know.
That sway bar linkage... not worth it, if you never put it back in... carry a wrench IMO.
Have fun! it won't be as bullet proof as the ZX though///:D
That's wicked James. What an upgrade. You're going to have a permagrin all of this coming season :)
Permagrin is right! CONGRATS!
See ya for Thanksgiving? :D
POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW POW
