Just picked up a TS kit for my 3 fiddy. I understand i will be down on power but I weigh 150 lbs so hopefully that helps some... Just looking for some input on necessary mods so that I dont blow up my bike (again) 1st time was in the sand, long story. Any input is greatly appreciated. Riding in Cle Elum, WA area mostly. Do i need a thermobob? Running engine ice gycol coolant
oops just saw you said FC350 so same as the KTM SX model
What year is your 350?
I don't own a TSS but I do own two, wait one 350. They are stout motors, I have 250 hard hours on my 14, all stock motor never changed anything but oil, Valves are still in spec. My 2017 I put 80 hours on it, only reason I got rid of it was it had good value in it and I wanted my street legal 501. Awesome bikes and they have great power, at higher revs they have more power then most 450s and lets be honest on a snow bike you spend more time in the upper rpms then at low rpms.
bike mods:
air intake: looks like you got a pod in the kit already but you could lean out your bike with pod. you might have to adjust your TPS to richen the bike once you add the pod.
drop the front sprocket down to 13 tooth if you haven't already
depending on model year a handle bar map switch will come in handy, if your bike doesn't have one. the 14 to 16 models had multiple maps loaded in the ecu but no switch to move between them.
radiator guards/protectors are highly recommended. with the rad guards you will need to block the air flow to the rads when your running temps are getting too cold 170f or lower. So most guys just cut some plastic that they can slide in and out of their rad guards to block the air flow
a engine temp guage is also recommended so you will know when to block air and when not to.
I definietly think that bike needs a thermobob, keeping your bike warm is going to be hard on some cold snowy days without it. I ride my 350 in the winter time on snow (with normal tires) and I could use a thermobob for it
