Factory Twin Pipes on Summit?
Just picked up a set of twin pipes for my summit 800. Its all stock w/ exception of boyesen rage cages. Can i leave jetting the way it was stock to test the pipes? riding 8000-9000ft 35 deg temps 400 main jets. I have heard so many mixed emotions about the twins, so thought i would try them out for myself!
Get ahold of Gus Bohne on here, or call the race dept and see what they recommend.
Sorry, I don't. Didn't keep any contact information when I left the dealership.
jetting twin pipes
If you are running a stock summit head at 8000 feet and the factory rack carbs you can run lower main jets than 400's. At sea-level we can run 420-440 main jets with those pipes at that temp. we also add a .020" shim under fixed needle (or raise needle one clip) at sea level and advance the timing a little..
Did you get a noticable gain?with these pipes.
yes, but better yet with crankshop mondo twins and running a little higher compression them cutting fuel with race gas. 10 hp gain with crankshops.
FYI: The ski-doo race shop ran taper bored mikuni d-slide race carbs and 16.5:1 domes with these pipes and jetting was 350-360 at something like 25 degrees f and at sea-level. I dont think they ever tried trail type compression or rack carbs.
A full race ported motor at 16:5 to 16.9:1 and these carbs will run usually a 380-410 at same temp and altitude depending on power.
