I'll post some pictures when I get a chance.
This is what I'm trying to sell as a package:
A complete M7 cpc 1000 motor (includes pistons, head, high compression dome inserts, cylinders, blueprinted bottom end, oil pump, water pump, power valves & cables, 4-degree timing key, & v-force 3 reeds, everything except stator, magneto, cooling lines, mag side motor mount bracket, & recoil starter)
Jaws twin pipes, muffler w/ egt bungs welded in already, & cylinder to exhaust mounts w/ grafoil donuts.
50mm aftermarket throttle bodies to replace stock 48mm (no injectors or tps)
Boondocker control box already programmed for around 7k to 10k altitude but will need fine tuning because of possible different intakes, fuel pressures, & ecu's.
I also have an extra head, 2 more HC dome inserts, straight 40 helix (for stock secondary), a set of extra head o-rings, primary & secondary springs recommended for use by Cutlers (don't remember color off hand but will add those when I look at it again).
The bottom end was rebuilt last season and a new top end was put in soon after that. The motor is really strong!! Guaranteed to put perma-grin on your face. I'm asking $3800 for everything plus shipping. I'm only selling because now I'm going bigger!!
