F/S Polaris Gen II Mod Chassis
Angermangement890
F/S Polaris Gen II Mod Chassis Make offer!
I am selling my Gen II Mod sled. Sled was put together in the fall of 04 and has been used only out west save for running some hilldrag events near home.
Chassis Specs are as follows:
2001 Polaris Bulk head new in 04
VanAmburg 159” Hill Climb Tunnel with Full length U-cooler, modified foot rests, suspension brackets, snow eliminator running boards, rolled chaincase and chaincase guard. Assembled by Mike @ VanAmburg with aircraft rivets
2001 belly pan modified for the drop and rolled chaincase and triple exhaust outlet.
Fox shocks with RCS TI springs
40” Fabcraft Cro-Moly radius rods with Aurora teflon hiem joints
Fabcraft carbon fiber trailing arms
C&A Pro Ski’s 10” carbides
Lightweight Polaris Jackshaft *
Microlite driveshaft by MicroBelmont with Whal Brothers 2.52 pitch 9 tooth drivers * and spare Whal Brothers TI Driveshaft
Lightweight HYVO gears * 18/41 many spare gears/chains
HOLZ coilover rear suspension on New Polaris 156” rails * with MTN machines Freedom Axle with 2 8” billet wheels *, shocks rebuilt by Carls Cycle 1-25-08
Ice Scratchers *
Camoplast 159” x 2” x 15” track *
Sno-Tek Power cranks for the steering rack
Sno-Tek Billet steering post supports upper & lower
Cromoly steering post by Wildchild customs *
6 new trail motor mounts SLP 77 durometer*
SLP lightweight Steering hoop *
CustomPowder coating on various brackets, supports etc. *
Fabcraft 2” taller bars with 5* pullback, has hand warmers and thumb warmers installed
Billet throttle block
2” bar riser
12 gal tank, 2 fuel lines, 1 for Boss Nitrous system
Boss Highrise Flattop with Nitrous pouch *
Custom -4AN nitrous line*
Complete intake system, sealed to the hood 8 flow rites, 6 -2 ½” 2- 5” *
2” taller Lexan hood painted red, headlight installed*, cracked have a new unistalled spare hood that goes with the sled.
Cobra Windsheild
Windsheild bag
Gears tool bag on the clutch cover *
Modified oil tank *
HOLZ racing lightweight brake disc
Garfal brake pads*
SLP extended brake line
NTN Formula bearings, Jackshaft, Driveshaft and Chaincase *
New oil seals for the chain case*
New Chain tensioner.
* indicates that this part was installed in the Fall06/Winter07 and has 250 miles on it.
Sled is currently set up to have an XCR 800 engine installed. Motor plate, airbox and other triple stuff is available with the chassis.
also have a Boss Nitrous system, complete separate fuel delivery system 3/8” line to a Mikuni 65 LPH fuel pump (will support 100 hp nitrous shot) 45 hp nozzles and 60 hp nozzles *
MAKE OFFER!
