P
paulharris
F/S mountain max part out!
ENGINE LONG BLOCK IS SOLD BUT EVERYTHING ELSE ON SLED IS AVAILABLE INCLUDING CARBS, IGNITION, ETC this is a running triple cylinder engine out of 2000 Mountain max 600. it fires right up and sounds good. mileage is only 1230! I did compression check and keep in mind it was checked at over 8000 feet in elevation. compression on all three cylinders are exactly the same 95/95/95. my guess this would be 120 or 130 at sea level. cylinders and pistons look to be in good condition i pulled the exhaust manifold off and looked inside and inspected them with a flashlight. no scores or any damage that i can see. the bottom end on these engines are exactly the same as the 700 triple. the engine will come complete less the reeds and starter assembly. the engine is still in the sled so if someone wanted i could start it over the phone. $575 call 206 909 9025 located in vail, colorado. thanks
I also have a lot of other parts available too. carbs, chaincase, driveshaft, jackshaft, 141 track, secondary clutch, electronics, exhaust, etc. call if interested
