Sled169
Helping a buddy who can't ride anymore this season and needs to sell his new 2012 Arctic Cat 800 Pro Climb limited. Orange and white. Has about 250 miles on it. Has HPS can and the stock can for it.
It is at the dealer right now getting the clutching update done.
He is asking $9750 for it. If intersted call Luke at 541 519 2146.
Photo is of the M1100, but the colors are that same on the M800 for the most part.
ENGINE
Type
2-stroke
Displacement
794 cc
Cooling
Liquid
Cylinders
Twin w/push-button engine reverse
Bore X Stroke
85 x 70 mm
Lubrication
Oil injection
Ignition
3D
Carburetion
46 mm dual throttle body batteryless EFI
Exhaust
APV with tuned pipe, pipe sensor and stainless steel muffler
Fuel Capacity
10.6 gal.
POWERTRAIN
Drive Clutch
Arctic 6 post (rpm sensing)
Driven Clutch
10.75" dia. Arctic (roller cam)
Drive Type
Arctic Drive System
Brakes
Radial master cylinder hydraulic brake / disc on drive shaft
SUSPENSION
Front Suspension
Arctic Race Suspension with FOX Float 2 shocks
Front Travel
9 in.
Rear Suspension
M rear suspension with Tri-hub rear axle system, FOX Zero Pro (IFP) shock on front arm, FOX Float 2 shock on rear arm
Rear Travel
15.5 in. (153) / 16.5 in. (162)
DIMENSIONS
Overall Length
125 in. (153) x 130 in. (162)
Overall Width
46 in.
Ski Stance
40-41 in. adjustable
Runner Type
Single skag w/carbide
Track Type
Power Claw
Track Width
15 in.
Track Length
153 in.
Lug
2.25 in.
Pitch
3.0 in.
STANDARD FEATURES
Front bumper, telescoping handlebar, low-height windshield, deluxe digital/analog gauge, electric gas gauge, low oil light, coolant overheat light, accessory outlet, high/low hand & thumb warmers
ENGINE
Type
2-stroke
Displacement
794 cc
Cooling
Liquid
Cylinders
Bore X Stroke
85 x 70 mm
Lubrication
Oil injection
Ignition
3D
Carburetion
Exhaust
Fuel Capacity
10.6 gal.
POWERTRAIN
Drive Clutch
Driven Clutch
Drive Type
Arctic Drive System
Brakes
SUSPENSION
Front Suspension
Front Travel
9 in.
Rear Suspension
Rear Travel
DIMENSIONS
Overall Length
Overall Width
46 in.
Ski Stance
Runner Type
Track Type
Power Claw
Track Width
15 in.
Track Length
153 in.
Lug
2.25 in.
Pitch
3.0 in.
STANDARD FEATURES
