B
bojihawk
New member
F/S 2008 Nytro, MPI stage 2 supercharger, prologger stand alone fuel system bigger injectors and high pressure pump , cold air intake, MPI intercooler pullied for high elevation 18lbs but have multiple other pulley options that come with along with block off plate for BOV if u wanna run max boost but not needed as this sled climbs like no other also has hartman clutching, engine all built up with arp head studs carillo rods and oem pistons just as good as any ,fan with coolant tank overflow removed, custom vents, vented headlight delete w/small halogen light, roll-over valve, all ur needed gauges with prologger and koso water temp gauge, OFT handlebar relocate and OFT billet blocks to replace wear prone plastic ones, updated oil tank and sub frame,5 inch powermad riser, aftermarket skinz freestyle seat light weight also have other custom made seat, Trail Tank, custom VE boonedock tunnel and rear bumper done by outlaw motors w/ above tunnel GYTR dual exhaust sounds bad a..,162X15X2.5 Cat track and skid out of 2009 m8 sno pro with all fox floats, Avid drivers, ice scratchers ,reverse, custom billet front shocks and timber sled front end with skinz skid plate. Sled works GREAT Needs nothing very clean cant get pics to load so text me at 712-330-0911 or email me at littlekirsch@hotmail.com ill get u pics!!!!! Sled located in NW Iowa $ 12000.00 obo over $30000 by guy who built it SLED WILL NOT DISSAPOINT
