Ez Ryde
U
Ultralord
well I got the T apex out today Holy crap she runs hard. But in the climbs I think only the last 6 inches of track were in contact makes it kinda hard to climb. does anybody have any sugestions in where I start with adjustments. The skid is a dream in the powder and on the trail sled is super stable. oh yea the Pl box was a huge change from the Boondocker box By far the best it has ever run.
good to hear you like it so far hope to have mine out on sat. :D have you moved your front swing arm to the upper mount hole ?
Install limiterstrap like nate zollinger did on his modsled that will probably help.
His sled was featured in sleadheads magazine.
sorry but M10.
Gee that helps A lot---- I have made no adjustments I was not sure if I should start with the shock pressures or go to the swing arm I would like to get it as good as i can before I install a limiter strap
ULTRALORD can you please post pics of your sled again!!! I love that thing!!! I look at the pics of it on lbdesigns eveyday b/c I can't wait for my sled to get done!!!
If you would have called we could have adjusted it on Thursday!!!
I played with mine for 4 hours on Thursday. I went home and removed the skid and drill different mounting holes based on my impressions of the weight transfer. I am happy as hell with the skid but mine needed more than just some spring and compression adjustments. (in my opinion the mounting dimensions they use are not great!!)
Ultralord, what boost are you running? That will play a huge amount in what kind of adjustments you will have to make. Did you have good ski pressure while cruising? My mounting dimentions are different than yours because of the D&R.
Had to tighten my track quite a bit aswell. So far I am happy with the sled just need to get it dialed in.
We tried to get up on Sunday but my buddy in North Bends power was out and he ended up spending a bunch of time getting power set up for his wife!
Sap
:p
Read the whole forum of replies.......That was the best help you got. Enjoy your "wheelee Queen"
was'nt able to get alot of seat time on mine apparently 20 lbs a boost on the stock rods is to much but I did talk to steve today and with the drop and roll the shock length is too long sending it out this week to get it shortend and the mounting holes on the swing arm needed to be changed as well hope in a month will be up and running
