C
cjgodden
Ive been battleing the rear suspension like everyone else. At the end of last season I tried pulling the center shock out and as far as I'm concerned it sucked even worse. I think it even exagerated the problem. My issue is I can get the suspension to be good in the small bumps and rige good, but at this setting big bumps it is too soft. When I adjust so that it can handle the big stuff it is way too stiff in the stutter bumps. After removing the center shock it seemed to sack out even quicker than with the shock there.
So my thinking is that we have been going the wrong way. it seems that the center shock is doing more than effecting front skid pressure the way a normal sled suspension does.
So I have came up with two ways to try, what do you guys think.
1. loosen the upright shocks to be where I like them in the stutter bumps and stiffen the hell out of the center shock. as it seems the center shock is effecting the lower end of the travel and this may hepl the sacking out.
2. uncouple the suspension by repositioning the center shock, I had this thought on the drive home tonight. What if I were to take the center shock and attach one point to the skid and the other the the shaft that the limiter straps attach. Or better yet make a front swingarm and and attach that to the chassis and the skid and the center shock to the skid and the swingarm. then the suspension would act like a normal skid and then I would be able to tune it.
option 2 is a little more in depth but I don't think it would not be that hard. there has to be a solution out there. I tired of getting my teeth jarred out and valving is not working and I'm not so certian that a dual rate spring system will work either.
Opinions?
Opinions?
