Does that use the BRP upper clamp halves?
Yes it does.Does that use the BRP upper clamp halves?
Did you just splice the handwarmer wires? Are you using the brp 2 wire warmers?
Nice.I use the BRP 2 wire.
You can purchase BRP style warmers with high/low.
I unpin the Polaris connector, cut off the stock pins, strip the shrink off at the warmer and pull the wires out of the Polaris loom/armor.
Snip the BRP pins off. Slide a 2” piece of shrink onto the stock loom then slip the wires through the loom and re-pin the wires. Heat shrink the loom to the BRP heat shrink and your done.View attachment 404350
4.5” or 114.3mmWhats the height of the riser?
Well, I wear XXL gloves. So that dog don’t hunt.Doesn’t everyone complain about the expert bars are for small hands. I guess you polaris riders must have small hands.
