Having a bogging issue with my 2012 RMK Assault. 3/4 to wide open throttle, if I keep a steady throttle I get a bog. If I let off and get back into it, it's gone. I have gone over plugs, wires and caps. Just cleaned the exhaust valves and was checking that solenoid in the system. Started the sled with it plugged into electrical but hoses disconnected and and solenoid unbolted. It doesn't open when I start the sled up. Took the solenoid into the dealer to check it and all is good. Unhooked electrical and started it and there is power, tried to check ground but hard to do with a test light. If this solenoid is always closed, just like all these people plugging those hoses, could it cause this bog. And is this solenoid closed when at idle? Also I don't know but I have only noticed this bog at home (3000 feet), never happened on trips to the mountains (5-6000 feet) but I figure that could be from the fact that I might not be as steady on the throttle when I am there.
