Not sure but I would think you should be concerned when re-routing this hose with at least 2 things.
One would be freezing-thickening of the goop at a stop or plugging with snow-ice in use. The other would be whether the ID of the hose extension is important.
Like I said not sure because I have never put my finger on the end lol while open and running. I did read something on the solenoid about 13 psi. Don't know if it has a check valve or pop-off pressure besides just an opening function??
If 13 psi is approx. pressure (less than 1 atm.) then that is not much to blow through a plug of goop or snow. If it is an important #, then I was concerned about pressure restriction by adding 400% to the length of that hose lol.
I do know if the valves don't open when they are supposed too, besides performance loss-running problems, it would create a dangerous lean condition.
So for those reasons I used a big ID hose for extending and left it in front of the muffler laying on the pan making sure it has no bellies to collect mung lol.
Anybody know the pressure at the end of the hose when it first starts to open?? Pressure at WFO??
Sometimes simple things are simple, sometimes not lol.
