exhaust valve hose relocate?
I vented mine down through the rubber around the exhaust outlet,inside the snow deflector so it doesnt get plugged. Been good so far.:face-icon-small-coo
I drilled a small hole hole above the left side a arms and ran it out there. Every once in a while I have to knock some snow off it but it has never plugged up.
Out the (factory) hole in the bulkhead above the front lower A-arm. Left side.
I routed mine to just behind the exhaust I drilled and tapped for a barbed fitting . Never had a problem with it plugging
I routed mine to the right side lower arm opening. I drilled a 1/16 hole in the skid plate about 3/16 back from the edge and secured it with safety wire.
No issues so far.
