Exhaust Springs
What do you guys run for exhaust springs? Double up stock springs? Or buy aftermarket springs that are stronger?
I have a 700cc so i only have the 3 hooks on the manifold and the two on the end of the pipe to the turbo.
From what I understand, the BD springs are 3:1 to stock spring tension. My buddy uses them on his turbo and seems to like them.
i use the bd springs on my sled, i broke one of them after about 100miles,
so i put silicone inside and outside the spring and let it dry before putting them back on
havent had a failure since
the vibration is what kills them
pull hard
bd springs 1300 miles on them no failures. the trick to get them on is use a heavy duty boot lace loop it then pull ,no crimping ,scratching with hooks, pliers which weakens the hook.,
I have had the same springs on my turbo for two years now. I took them off a old lawn chair I was throwing away.
You can get them from Dakota Performance for about $2 a spring.
His number 701-452-4212
dakotaperformanceinc.com
