exhaust sensor wiring
tweeds
New member
Hi there!
It's been a year almost to the day and finally got time to put my 900 back together. Everything back in and all that's left is to install the exhaust. Get that all done and ..... can't find the harness the exhaust sensor plugs into!! Gotta be something soooo simple that I'm missing!! Downloaded the wiring diagram from here and traced wires back. Still can't track down!! Short of pulling the fuel tank off and checking to see if I somehow tied it back by the ecu. Getting frustrated. Can anyone help? Does anyone have a pic? I took pics before disassemble but the exhaust was off. Can't find in the pic. Any chance the wiring would be different color? Any help would be appreciated.
'05 900 166" Anniversary
SLP pipe & can
SLP rad delete
Team tied secondary
Thanks in advance
It should be two bullet connectors near the coolant sensor wiring, just above the stator housing. Mine was routed in a convoluted tubing so it was kinda obscured.
Thanks a ton!!!
Got tired of looking at the wiring harness all stripped apart and decided to go for a rip on the pro 800! Came back and saw u replied!! ( many thanks again)! I knew it had to be some thing easy and of course.... When I pull everything apart I unplugged the exhaust harness and to make sure I remembered where the wires went ( obviously didn't work) I plugged the harness together and stuffed inside the split loom!! What a dummy I am!! Lol it's all going back together now!!
Should mention that if you have a blk wire plugged into a white wire .... Probaly something not correct....
And depending on mileage etc may want a new one as well. Unfortunatley they will
" stick " on readings Dealer can verify operation easily with DW.. Mine was good for
2 seasons max??
