Exhaust probe sensor, help!!
oldstyle33
Have a 08 dragon, and the the check engine light is flashing 5 times so i replaced the probe. The engine light still flashes 5 times. But when I am doing a few good climbs the light will go off. Then, as soon as you are back on the trail or tree riding the light comes back on. Any help would be appreciated! Btw if it matters i have a bmp pipe, "fix kit" and pcv
Are you sure it's the Check Engine and not the Service Engine light that is flashing 5 times? The service light will flash when the preset service hours are hit, a turned mine off. Just checking to make sure you aren't tracking down a non-issue.
EGT probe
That ought to be enough to reset it. Check out the other post by MORSNO to make sure you are not chasing ghosts...
Just got to my sled, and it is the check eng. light. Where would the service light be? They aren't the same light, are they?
