P
I bought a used y-pipe and it has the bungs for the EGT's welded on the pipe. On my current y-pipe I have the clamp-on style connection. I'm trying to remove the clamp and threaded sleeve and it appears all I need to do is get the compression fitting out of the threaded sleeve and the threaded part should slide off the sensor. Problem is, I'm not sure how to remove the compression fitting w/o damaging the sensor. I've included the link to the setup I have now and the compression piece i'm trying to remove. Any help?
http://www.exhaustgas.com/ProductDetail.asp?ProductID=857&DepartmentID=1&CategoryID=57&RepID=&BasketID=
