C
catmanm7
So I kept my stock pipe donuts on both ends and made my own clamping system similar to OVS (bolts and springs). Anyway, I pressurize my system to about 5-8lbs. Only way I can hear leaks is by using a boost line as a stethoscope and hearing a little hiss. I can run this sled on a stand in the shop and it may hit 5lbs with boost knob turned way down. I think once I take it out the leaks may get less once everything start to seat in and the turbo is under a load. I am also going to try some heavier springs as well and the donuts are brand new. When I installed the donuts I used the RTV red high temp silicone all over them. I thought this would be better then the copper gasket stuff because it will allow the exhaust to move a little more, and the silicon is a lot thicker then the copper gasket material.
Also, were the rod for waste gate comes out of the turbo housing, I have a small air leak there,and will drip oil, probably from my 2stroke mix, not the turbo oil.
How anal do I need to be on this stuff, I am positive that my intake leaks are fixed, but how important is the exhaust side of it?
Should I try the copper gasket stuff instead?
When the exhaust donuts heat up, will the seal a bit more?
Thanks, I will be taking it out this weekend regardless, I just dont want to end up with a fail for the first time out. So anything I can do as a quick fix will help
