EVO big chute Clutching?
H
HCM
What is working on these I have one and sled runs but the Clutching is got me wandering have over a 100 grams of weight in the MDS weights and it is still bumping 8560 Rpm when you get it wound out, I still think the secondary spring needs to be a bit stiffer so it does not pull the belt in the clutch, every thing is what said to run I guess keep putting more weight in? don't no how to get much more on the weights. thanks
I would call eric at Racinstation if you already have mds in there. He has lots of time with those on the 1100. I've never played with them so can't help you there.
weight
how did you get that much weight in them? sure seemed like they maxed out in the low 90s to me..
I agree I figured I hd about 93.5 grams in mine and that was the most I could fit.
I live in mn and the same clutching that works at 7500+ feet does not work at lower elevations in mn. My clutching setup from racinstation worked perfectly out west but I can't keep it out of the rev limiter here in mn. I have asked Glenn hall bout getting the clutching setup for here as I know he is making big power n knows how to get it done t low elevation. His suggestion was actually a helix in the 44-48 range for low elevation.
After talking with Eric at racing station he said i am running close to 93 grams got both gold bolts with washers and nuts on both with the plate on the weights, but got a team coming for it so I can get the power to the ground, got to get this thing to run so it can pull some chutes.
