im with BCL, my mind hurts when people say you cant run av.Haha it's ok to laugh at it cause I did to. I've heard a lot of people say they use it but never have researched it. I won't say who told me don't wanna throw anyone under the bus. I'm not a fuel or engine guru just have basic knowledge. so figured I'd pick everyone's brain. Plus I'm laid up with a knee injury after the weekend and bored outta my mind and it's way to quiet on hear
Turns out doing a Google search brings up all the old snowest posts about this topic but snowest search comes up with nothing. Found enough of info to give me a warm fuzzy to try av instead
Bringing back an old one here, but I recently ended up with a turbo'd XM.
Are there issues with blending AV/91 pump with ethanol? I'm guessing no.
What about storage issues? AV stores great. Ethanol not so much. Would it be ok to leave the blended fuel in the tank over the summer? Would the AV counteract the ethanol?
Personally I would siphon out all remaining fuel and dump in 2 to 3 gals Avgas, fire it up and let it run through a bit.
I'm not done riding for the year yet!!! Suppose to get more snow this week, but I will do that!
Interesting I have 2 buddies running T-3's with boondocker Turbo kits at 10 pounds boost on strait Av .What elevation are you riding ? CheersVerdict is in. My Etec hates AV gas. It was pulling timing pretty bad with straight AV. Siphoned it all out, filled up with VP110 and she was happy again.
800 miles on my TEtech on 10 lbs with straight AV, ran perfect the whole time. I'm thinking you may have something other than a timing pull going on...
Ok you say it is pulling timing.....do you have a code or is a seat of the pants feel? If this was a low octane problem I would think the first code you would have would be DET. This just a guess. Think, if you changed fuel and it now runs better what has changed in the system? Was your Av gas good? Does one fuel produce more heat in the system then the other?
I run straight 110 in my T-Etec at 6-10 lbs boost. Pump gas and T-Etec just doesn't make sense to me.
