chrome it and it wil go faster
internal combustion engines are cooled when combustion chamber heat flows out through the piston crown via the rings and absorbed by the cylinder wall and then carried away by coolant or air.
As you make more hp it requires more combustion chamber heat, so as engine make more hp, the piston crown and rings and cylinder walls have to operate as peak efficiency.
Steel tranfers heat slowly.......so steel pistons went away 60 years ago replaced by better heat transferring aluminum pistons.
By the early 70's performance engines needed aluminum cylinders to get rid of heat created by bigger HP numbers, so we had chromed aluminum cylinders, but the chrome was soft and flaked. Kawasaki helped pioneer NICISIL they called it electro fusion bore. Now your 125 could scream at razor lean jetting and not seize if you had your chit together. Aluminum piston flowing heat to aluminum cylinder.
So now you want to go back to slower piston/ring heat transfer with a steel liner. No big deal. Just keep your engine comfortablely fat so it runs cooler. Find some rings made to run on a steel surface ? Knock down the hp and rpm should be ok.............like we were in the 60's.
So unless hp and safety are a concern, steel liners are fine.
