mine would go off after unloading from the trailer,after driving to location.I think it gets moisture on the sensor.
It would clear up in 10 minuits of running.
Also check the connector,and put some electrical grease in it(should do this to all the connectors anyways,will help keep moisture out,and reduce corrosion)
Hope this helps,good luck
D
