Engine swap wiring question
Can anyone tell me if the zx 600 wiring is the same as an 800?
Ive found a 600 for a reasonable price and was thinking about swaping it in place of the dead 800 in a 2002 summit.
Thanks
The plugs will be different for the stator and pickup coil, does your 800 have Electronic reverse? 99 2000 600 didnt have electronic reverse and I dont think there is a place on the block for the second pickup to operate the reverse. You should be able to use your stator but you will need the 600 mpem also for the proper timing and DPM controls to work. To make the swap easy you should look for a 2002 600,700,800 and it will be a easier swap.
No E reverse on the 02 800.
Ill have to check to see if the 600 comes with the mpem.
Thanks for the help.:beer;
