Out riding yesterday. Sunny spring conditions.
Lost power to MFD completely. Then MFD would flicker. Was on long enough to see EV code come up. Lost power to MFD, limped sled back to truck.
Relays on bulkhead cross member were cleaned, dialectic greased, covered (by previous owner). Relay in bag over primary clutch had light corrosion, I cleaned male and female connectors and reinserted.
No change.
When sled is running, no 14v output to "gauge power" plug above primary.
When I supply 12volts to "gauge power" plug. MFD powers up and EV activates. When I fire sled up, with external battery powering MFD, I get no codes or check engine light.
Need to determine where power loss is on MFD circuit.
Suggestions welcome.
Will keep you posted.
Thanks in advance.
No change.
Thanks in advance.
