New to the Poo sleds, have there been changes to the 2015 800 that warrant it more reliable than some of the older years, I have heard of skirts and other reliability concerns?
Sweet ride! I pulled the pipe of my 2015 to put on skid plate and ultimate bumper, and the inside of the y-pipe was not what I typically expect of a 2 stroke... it was kind of a light yellow-ish, and dry as a bone.X2, just bought a Pro also, (The Rev is the Wifes sled now) its a 2012 with New 2014 engine and every 14 running component and a New 15 track swapped to the 12 chassis, less than 300 miles ago, lots of mod parts and goodies like the 36in Zbros frontend/ dual rate springs, 14 Burandt running boards, etc... Only thing on it left 12 is the tunnel chassis and the rear skid and guage panel, still has the chaincase. which I like.
Anyway also would like to know like Byeatts asked, what can we do to the 13 and newer engine to improve reliability?
Wildcard
Sorry to hear that.Good question? I just grenaded my 2012 with less than 1300 miles due to the cylinder skirt and am wondering if I should put a fix kit on my 2015 to prevent the same thing from happening.
Ouch. Here is hoping (for my sake with my 2015) that your 14 was an exception to the rule... everyone I have talked to locally and based on non-scientific observations on posts of premature engine troubles here on snowest would imply to me that 2013 and newer are GENERALLY more reliable than 2012 and older Pro motors. Speaking to people I have known for many years at my local Polaris dealer (who have nothing to gain as I don't buy new sleds from them, just parts and occasionally service) who observe what sleds come in and out with issues, and who also ride Pros, have also said that the newer Pros are much less prone to catastrophic failure (they sell quite a few and have had very very few go down). Was even considering buying extended warranty from them while my sled is still under factory warranty and eligible, they told me they wouldn't do it as the 2015's they have sold have been solid (with 2 dealership outlets they sell quite a bit).I'd be a wee bit scared to ride an year model without warranty. My '12 was pretty bulletproof, but my '14 may have the worst warranty record in Polaris history. Scuffed pistons at 1,100 miles, crank broke on clutch side at 1,400, crank broke at 2,400, crank broke at the exact same spot at 3,300. Polaris has been great with long block motor and clutch replacement, but I'm afraid to go to the other side of the mountain when my motor has more than 40 hours on it, It's been a real GEM. It still has another season of warranty left, Thank God. Should be worth another long block or two. I used to praise the reliability of the Pro motor.
I think you will be good to go for quite a while... just throw a set of pistons and rings at it every once in a while to keep it fresh... and turn up that oiler...Hoping for the best on mine, No warrantee buy like mentioned earlier, 2012 with less than 300 miles on a complete 2014 engine conversion.
Wildcard
I'm not sure what the deal is with this sled, but it sure is getting annoying. When the crank breaks the stub is stuck in the clutch. Polaris has been providing a new long block motor and clutch. The sled is on it's third clutch which kind of takes the out of balance clutch out of the equation. We have some conditions in NE Nevada that are not synonymous with anywhere I've ever ridden. We get a good dump and then a week later the mountain is 100% traction and generally hard as hell. Out of every 1,000 miles, 350 to 400 are spent climbing some of the steepest, nastiest biggest traction pulls you'll find anywhere. I'm 250 lbs. with gear on and have a feeling that motor is not strong enough to pull 250 lbs. upslope all season long. The 160lbs. folks I ride with don't ever have any issues. I've been destroying Polaris crankshafts at one or two a season since 2001. I love the Pro Chassis and couldn't ride a Skud if my life depended on it. I kind of stuck dropping off the wounded sled at the dealer once or twice a year until my warranty expires.
Redline oil is great stuff, with the oil pump turned up I think you should be good. Carls recommends redline for all their big bore motors (like my 860 Dragon) and they have the pump turned up too, that motor has been trouble free for me as far as wear goes (pulled out pistons with about 1500 miles on them and they looked almost like new - maintenance replacement).Thanks, the previous owner said he turned the oil pump like he does on all his pro`s I believe 2turns, should we add some oil in the tank also? this sled engine has been on Redline out of the box
Wildcard
