C
coug66
Provided I have a ball bearing turbo, which direction should I go?
Twisted turbo pump gas M1000.
I bought an electric oil pump picture below
I assume with this turbo since it pumps 30 GPH ( 4 to 7 Psi) that I would need a restrictor
My worries with this system is if the power wires become disconnected or it fails. I don't want to lose my turbo over it. If the pump fails will there be signs that I can investigate before I loose the center section?
Is it better to just use the engine pump and keep the oil line attached to the water pump?
I would really like less issues to worry about.
