Engine light.
Engine light
Check you wiring at the ECM and harness for Green on pins and harness. Should clean it and put dielectric grease on them. If that doesn't fix you may need to replace them as we did on one of our sleds.:face-icon-small-ton
I have seen the CEL flag sensor's and other times they are nuisance indicators the computer sends out. Check the sensor's on the engine and all the electrical connectors. Disconnect one at a time, make sure you don't find any corrosion, dirt, ect.in any of the connections. After that smear some dialectric grease, vaseline, on the fe-male side of each connector. It couldn't hurt to pick-up a can of electrical contact cleaner and clean each connector, inspect, and then do the vaseline.
Wally World has CRC electrical cleaner for a couple bucks a can.
Thanks guys that gives me a couple more angles to check.I went through the dpm tonight it all looks good.
