The engine light has started to flash five times on my -05 RMK 900 and from what I've read it does indicate a problem with the exhaust temp sensor.
It's not flashing all the time, it comes on every now and then.
As soon as I let the revs down under 3000 rpm it stops flashing and I can then often ride for many miles before it startes flashing again.
It never flashes from startup, it always starts after I have ridden for a while and the engine is up to temperature.
I have not felt any changes in performance, it starts and idles as usual and pulls like a beast.
No overheating, no other problems.
The only change that was made to the sled prior to the problem was fitting a 4" riser block and extending the wiring to the handlebars. That was done by soldering and shrinkwrapping the joints. The sled was then ridden a full day over more then a hundred kilometers without problems, and the day after the light came on for the first time.
I've searched extensively and come up with some different possibilities:
- Bad exhaust sensor: seems most people have constant 5 flashes from startup til engine is turned off?
- Bad wiring: where does it usually go bad and wouldn't that also men that the light would come on from startup? Ar least sometimes? And would the light go out immediately at idle if the wiring was bad?
- Engine actually running too high exhaust temp (too lean) for some reason?
Thankful for any thoughts around this that can help me solve this puzzle![Smile :-) :-)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cheers
Dan
Cheers
Dan
