Engine Hiccup fix
Calvin42
Got some intel on the issue causing the sled to run erratically. Some of you may already know this, but I'll pass it on anyway. The small nylon bag just above the clutch guard on the left side of the sled, contains (one) small square relay. Remove that relay and clean the contacts if it shows corrosion, apply dielectric grease and re-install. Apparently that controls the exhaust valves as well as other electrical components that will cause your sled to run poorly. Now I know there has been discussion on the other electrical component that looks like a woman's pleasuring device has been the problem, that apparently is not the issue.
Any photos to help show the exact relay? Thanks...
I can take some pictures later, however, it's the only square relay in that nylon pouch above the clutch guard towards the front. I have heard of people swapping the round cylinder looking transformer, but all of those that have been swapped and subsequently tested have tested good. I would focus on the square relay. Will try and post pictures later. Should only take about 10 minutes to take a look at.
Very good... sounds easy enough to find the right one without pics. Thanks...
