High miles? Crank/Rods tired??
Less than 300 miles since new crank and pistons.
Yep I agreeThen you had some other issues. That blow-by is a dead giveaway that you had a bad piston/cylinder. Did you use OEM? I'm betting that if the pistons were good, the rings installed right you probably had cylinders that were out of spec and in dire need of a re-nik. New pistons in a poor cylinder is just as bad as old pistons in a new cylinder.
On trail to riding area, 30 mph, light throttle. Heard a bang, coolant everywhere, hole in engine case. Took it apart tonight and found that the PTO connecting rod broke about 2" above crank pin. Any one else seen this happen? Thoughts?
2005 Summit X
Ya it's not always BRP's fault got over 7400 miles on my HO,But IF you have a PSI engine i'm sure your no stranger to daily maintenance.Seen it many times. Ski doo been using that same 1500 mile motor for way too long now..
Thanks for the input/responses. Pretty much decided to sell/part out the Rev and get an XM.
Good bye old friend, it's been a good ride!!!
