M
maelstrom57
New member
Recently purchased a slightly used '09 M1000 x 153" with around 700 miles. While giving it the go over, I see the unit still has the factory clutch setup, 6000' to 9000'. As I only run less than 3000', my first question is how much of an improvement is possible by changing the clutch setup appropriately. The unit is completely stock but I plan on doing some low level mods later. So, should I just have the clutch setup now for the 0 to 3000' I'm running or wait and do all the changes as part of the total package which modding. i.e. Just hold off and do everything at once. Either way, I'll have to pay someone to do it, so if the initially clutch change will only give me a marginally improvement I would probably wait until the end of the season when I do the full mod job. I'm not sure at this time how far I'll go as I would prefer to avoid a fuel controller. Additionally, the machine has a pretty severe bog around 6000 rpm when gradually applying the throttle. Would this clutch setup be partially responsible for this issue?
