D
Delo
I have a 2006 Summit 800X. I removed the electric starter because it was not working. Now the problem I am having is the lights & tachometer do not work. I put the ground wire back on that was located down by the atarter. All I did then was remove the battery bracket that was by the chaincase. I unplugged the solenoid (2 things to unplug) and then zip tied all the wires that came off the top of the battery bracket together and tucked them back towords the motor. Those wires are still connected to whatever they go to. The sled does start by pulling it now because a relay was changed. Does anyone have any possible ideas on what I did to cause the lights and tach to not work? Thanks.
Delo
Delo
