2016 LTD Proclimb M8000.
Pulled the sled out of the corner today to get ready and ran into some electrical issues. Headlights, gauge, and tail light don't work. I checked the three fuses up front and they are all good.
When you first start the sled up, the gauge and the lights will come on, within a few seconds everything goes dead. If you start it back up right away, there is nothing. If you wait for a while, it will do the same thing again. There is a very very small amount of juice, just enough to make the old bulb have just a slight little hot spot you could see start to turn orange. I think it was like .002 Volts or something like that...
Checked the 12V outlet and it doesn't have power either.
Before I ever started it, I put in new LED light bulbs because I had one broken bulb I need to replace anyway. Didn't start it before putting the LED bulbs in, so not sure if that has anything to do with it. It doesn't seem to matter if I have them plugged in, unplugged, an old light plugged in, or any combination. The gauge and lights (whatever is plugged in) will shut off within seconds after starting.
I've checked the main connector for the hood as well as the gauge connector for pushed back pins or corrosion. Made sure they were tightly connected several time. Checked grounds on the chassis and engine, checked all the other connectors I could find on the handlebars and in front of the gas tank. I'm at a loss... Any suggestions? Anyone seen this before?
I tried looking up the voltage regulator on country cat and couldn't find it. Is it built into the ECU by chance??
