P
pura vida
i'm having so electrical issue on a carbed 07 600. every time i start it up it flashes the service engine warning and then goes into its normal function. other times while riding the entire display will reset, as if the sled was just started. and then there are times when i will start the sled and neither the display or lights will work. i'll shut it down and restart it with the same results. then on the next ride everything will be working "normal". also, the majority of the time my brake light, the one on the dash not the actual light, flashes or flickers when the sled is running, regardless of RPM. if i grab the brake then it will hold solid but many times the dash light will be on completely, even without pulling the handle.
i thought it might be a bad ground so i checked into all of the grounds and they were in good shape. i even added some grounds just to see if it made a difference. it didn't. any ideas? regulator? cdi? fwiw, the run-ability is never effected. runs good all the time regardless of what dash or light issues i'm having. can i bring it to a dealer to have them pull the code? is that possible on an 07 carb? thanks
pv
pv
