Elctrical Problems With My Zx!
D
dpops211
New member
I have a 03 600 H.O. and all my lights went out all at once. Head light, tail light, dash, everything. I was told that if it was the voltage regulator, my bulbs would be blown. None of my bulbs are blown. Anyone else know what it might be? Im thinkin the stator?
Under the the left foot well there are some relays,,,one of them runs the electrical,check those,,,failing that, check the reg/rec as well
Samething happened to mine 03 summit 700, I want to say voltage regulator. It was a 30 dollar part. PM me if you want I will get the part # for you
ok tried some stuff this weekend. I was messing with the wires and i accidently reversed the plugs for the headlights and reverse. When i started it up, my headlight popped on but my reverse didnt work???????? which makes me think its not the voltage regulator?
I just had the same problem. It was the secondary load relay. I had no guages, lights, hand warmers, or reverse. It is on the chain case side, near the fuses. There is one screw that mounts it to the aluminum just in front of your right knee. If you have a buddy with a similar zx, you can switch it out to try it. The dealer should know all about this problem. Good luck!
Tom
I had the same thing with my 03 700. It was the relay by the chain case. I used a relay from NAPA that I had laying around. Same exact thing fit the plug and everything works fine. Much cheaper than the dealer relay I am sure.
fixed it. it was the little 1 inch relay box above the chain case next to my fuses. NAPA part number ar272 fixed everything. thanks guys.
