El. reverse to a 07 M1000??
R
Rms Rydning
I belive a saw a tread here about getting a kit to make electricel reverse,where the engine turns backward like the 09 sleds.
Do any know if a kit like this is available?
From what I understand it will not work on the 07's. Only the 08's and 09's.
Bummer deal for sure.
Something with the ECU. If you can find a 08 or 09 ECU you can make a go at it.
Thunder
I have heard the same.
My understand is that the 08 ECU has different wiring allowing it to take the programming. A cheap kit and you have elec reverse.
No go for 07's
won't work on the 07. Be careful, the 08 oil pump will not operate while in reverse if you reverse the motor, may want to premix or get an 09 oil pump if you do it.
