egt temps
Mine is, 70-90 different at idle almost all the time, and had been for a long time. The mag side being the hotter temp. EGT's can be a mind fack, untill you get used to the personality of your sled...
it was on idle, this is my first turbo sled and first with egts so wasn't sure. checked with a friend that has the same sled and he says that is normal on warm up/idle.
thanks for the replies
with that big of a temp difference if it where mine I would keep looking. things I would check ,air leaks intake boots,gaskets,power valve gaskets seals,might check reeds if they havent been done latley. might have one set of reeds not seating correctly , depending on which side is running lean crank seal lastly.
