EGT and Coolant temp guages, whats the best out there?
Putting nitrous on a big bore. Whats the best set of guages out there? And also, what type of nitrous should i run? Dry or wet? And whose system? Thanks in advance
I'm still a fan of the Avenger (II or III) gauges for both their look and functon. They don't make them anymore but you can still find probes and gauges in swap-meet, they are very durable and seem to last forever. JMO-
EGT - KOSO makes a wicked gauge. Overtemp flashing etc. Easy to program and even easier to install etc. Just make sure you get a rectifier with it from whoever you buy from and make sure you do not over-voltage the gauge. They will tell you it can handle 20 volts, I will tell you it can't and won't. Wire it to the same power source as your handwarmers or headlight and you will be fine.
Coolant gauge I just use an automotive gauge.
http://www.autometer.com/cat_gaugedetail.aspx?gid=2628&sid=7
NSC
Koso makes a new Duel EGT & Coolant gauge with RPM as well that will be new for next year.
It can be set up so if say you have RPM and coolant on display on a wide open throttle run but unknown to you your EGT's go hot it will automaticly take the coolant temp down and throw up your flashing red warning and the current EGT readings. I have a few of these on order so let me know if you have any more questions.
Finally. They are going to start making what Avenger had. That's good to see. What are the prices going to be like?
When Auto Meter bought out Avenger they discontinued building them saying that company never made money. That's the way it goes. I love my Avengers and like my Koso, just wish they had coolant temp. Glad to see this and RPM.
Dave
NSC
x2...and i have had digitron..!!!...Koso egt is very impressive..
