There is not more power to be had on lower octane fuel at elevation... Despite what most think... lower octane fuel does NOT burn slower than higher octane fuel.. The burn rate is the same... what is different is the flash point or the amount of heat it takes to ignite the fuel.. Once ignited, the rate of burn is the same.
There are tons of misconceptions out there regarding race fuel.
At elevation, your engine does not require premium fuel and will run fine on the lower octane fuel , will it run better? maybe.. but not because, with 91 octane, you have too much octane, but because your fuel is igniting later.
With the lower octane there is a good chance that the fuel calibration (FI or carb) will be better suited than the higher octane at altitude. So, take the same sled, lean it down, and run 91 octane and the power will be the same as stock calibration with lower octane fuel (maybe even a tad better). We run 91 octane in our stock sleds and mod sleds.. The mod sleds require it, the stock sleds do not. Could we run 87 in the stocker?? probably... will we?.. not likely.. Will this octane change make a noticeable difference on the hill pull?? not likely?
Compression ratio is the same no matter what elevation you are running.. Cylinder pressures are not.
I wrote a little tech article years ago that relates.. If anybody would like to read it.. here is the link
http://www.2strokeheads.com/tech2.htm
Kelsey
